G
GNNMartin
A black plastic cold water header tank has split in our roofspace, and we need to instal a replacement. I want to ensure if possible that the replacement is of good quality.
The failing tank is one of two, each of capacity 25 gallons, ganged together. The replacements will have to be 2 coffin tanks ganged together if we are to get them into the roofspace through the existing access. We decided to replace both tanks, reckoning if one has split the other is unreliable.
We had the failing tank installed as part of major building work about 23 years ago. I feel we were unlucky or had a poor quality tanks installed: I would not expect a black plastic tank to fail so quickly.
1: Who can be relied on to supply a tank of good quality?
2: How long (as a minimum) should a tank be expected to last?
I am inclined to buy a Polytank tank, since that is the only one I can find for which I can find information about the manufacturer. However, if anyone here has advice I will be grateful to receive it.
