Discuss How does a TRV work in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
trigger25
Apologies if this is a double post, I thought I had posted a message but I can't see it.
I had a radiator which wasn't getting hot and on closer inspection I found the locking nut was loose. As no water was leaking I unscrewed it completely. What I found was a valve with a central pin slightly protruding so not wanting to make things worse I replaced the TRV top. Having tightened it I found it started to work. As I could see no physical connection between the parts I was curious as to how the device works.
Trigger
Wax bead in the head expands with heat and depresses a plunger which in turn presses down the pin which closes the valve.
Different settings on the head denote different temperatures.
Reply to How does a TRV work in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hey guys in the know. I have paid for a heating and plumbing contract and had to pay my excess 3 times for the same thing still not fixed. The...
  • Solved
Hi There, I want to swap out my old valves for TRVs but the threads are different sizes, and I'm unsure how to resolve it. My current existing...
2K
Daley power
Hi All, I thought I'd come to the experts and see if anyone is installing and/or recommending the use of any Smart TRV valves? Particularly in...
2K
Hi all, We recently purchased a house and nothing seems to work correctly here, I've spent weeks rectifying issues. Plumbing, electrical...
5K
Hi, I'm getting a Tado smart heating system (have a gas combi boiler). I don't have TRVs currently, so I need to get a plumber to replace my old...
2K
