Discuss How to fit mixer taps to non standard tap centres? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I want to fit a shower mixer tap to my bath but the bath holes centres are 185mm. All the mixer taps I've seen so far require tap centres of 180mm.
Would I be able to get away with fitting a 180mm mixer tap to 185mm centres?
Is there any adapter or fitting that I can use to accomodate fitting bath taps with 180mm centres to bath holes of variable centres?
Mixer taps with adapters are available, or you might find the dimensions of a deck mixer would accommodate filing holes to suit centres.
Sorry for my ignorance but is a deck mixer where the brass body covers/runs from one tap to the other e.g Java Deck Mounted Bath Shower Mixer | Java Bathroom | Bristan?
The alternative being the pillar type?
Can you provide more details for the adaptors - perhaps a link to an image and how they are installed?
The Bristan 1901 can be adjusted 100 - 200mm centres but comes at a price. Deck mixers are as you supposed.
Reply to How to fit mixer taps to non standard tap centres? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Our kitchen mixer tap has started dripping. Like so much of the plumbing in our almost new build bungalow, it is lacking! The plumber didn't...
