• Thread starter Old Account
  • Start date
  • Replies 25
  • Views 133
  • fix
Discuss HOW to fix that ...... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
O
Old Account
hi lads,
Does anyone have not idea how to fix that leak? Any chance of getting a new part or something?
The leak is coming from where the blue towel is.
Below you will see picture
KIND regards,
Ron
What's with the ar / id label Ron ?
GOOD question,
I haven’t seen the job yet just received pictures today. I have asked her why she hasn’t replaced the boiler yet. She had an offer of British Gas for over 4K ...
Basically, she wanted it temporarily fixed. Shall I not touch it ?
It's a gas boiler ron are you gas safe ?
Flow switch will need replacing. It’s an “o” ring seal and will need the brass face cleaning back up, before reassembly.
No need to be gsr for that bit.
They all leak like this there is an estate near me that has them fitted. whats the best storage combi to replace these (sorry for the thread hijack)
viessmann 222
true but the ar / id label and the appliance isolated needs looking at which requires you to be gas safe
(second pic right bottom)
just a bit bigger than the max (100mm ish)
Easy switch swap if you do it , SIKA switch I think .
Tighten up with a “ strong hand “ not grips . The big tip is the flow switch has a small arrow on it , make sure you dont get it upside down or the fun will start .
Thanks a lot chalked. Do you know where to get a new one or would you just replace the o ring and clean the rest up ?
I am interested as well, good question. Have you changed the part before ? If so where do I get a new one?
Customer has stated that British Gas has put it there years ago due to the fluid pipe ... whatever that’s means ... I did not understand what she meant by this.
Thanks dude. Do you know where to get that ?
Customer has stated that British Gas has put it there years ago due to the fluid pipe . whatever that’s means . I did not understand what she meant by this.
Why has it been turned off then ???
What brand of boiler is it actually ?
Personally Ron. I wouldn’t touch it. These boilers are prone for rusting flue gas parts and flue issues. Do you really want to be the last person that worked on it??? I wouldn’t. A well know company killed someone with one years ago and they were trained engineers.
Ronny leave it alone do you need the hassle what happens if you replace it and the boiler wont work ? Let a GSRi sort it mate . cheers kop
It's a Range Powermax.
Very tricky boilers.
Why are we talking about gas boiler repairs on an open forum?
Is this not against forum rules?
Plumbers arms .... but yeah I will leave that . I already have spoken to her that I’m not going to touch it due to the fact it has a at risk note already. If she wants I can send a gas safe engineer to give her a quote for replacing it perhaps the viessmann 222 as I read above would do a perfect job.
But hey, thanks for the advice again and guiding me in the right direction. Much appreciate it to all on here
Reply to HOW to fix that ...... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hi all, i need help to fix the leak from a pipe connected to the water pump via flexi pipe and it is feed from the immersion heater. I have...
Hi, Hi wonder if anyone could help? I have a customer that has recently had backflow problems with her cylinder. She gets very hot water coming...
I’m experimenting with the installation of a floating countertop / basin. At the top of the picture are the brackets I’m considering using. Below...
Not exactly a plumbing problem but here goes. I have known for a couple of years there was a water leak somewhere between the water meter, on our...
2K
Hi everyone, I have taken out the heat exchanger because a tiny leak was found around the red gasket at the top of the heat exchanger of a...
