Discuss Hyco Handyflow Undersink, When turned on, causes tap to drip in the USA area at PlumbersForums.net
L
Liam CH
Hello! I have recently gotten my sink installed with the Hyco Handyflow Undersink. It works great and makes the water go hot. However when I turn it on to heat the water, it causes the tap to slowly drip. When i turn this off, it seems to stop dripping.
Would there be any indication what the problem is from anyone?
Sounds normal as the water is expanding when upto temp does it stop dripping ?
The Hyco is supplied with a vented tap, so it will drip to relieve expansion when turned on.
If thats just a “ normal “tap it doesn't sound right , post a pic of the pipework under the sink
I had to make an account to get the picture functionality working.
I'm not too sure how these work, so if this is normal then great! I don't know how long estimate it will take for the dripping to stop, i shall test that out now.
Here are the photographs
I've just had the heater on, and after about 10 - 20 minutes it's turned off, the dripping has stopped and the water is heated!
So my lack of understanding is my failure! As people have said, it's normal due to the vented tap and expansion of water. Once the water is heated, it stops the dripping stops also!
Sorry for the silly question!
Make a sign up to tell as it’s common for people to try and keep turning the hot tap as it’s dripping and it breaks the tap
Reply to Hyco Handyflow Undersink, When turned on, causes tap to drip in the USA area at PlumbersForums.net
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few...
Our kitchen mixer tap has started dripping. Like so much of the plumbing in our almost new build bungalow, it is lacking! The plumber didn't...
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
