Discuss Hyco Handyflow Undersink, When turned on, causes tap to drip in the USA area at PlumbersForums.net
L
Liam CH
Hello! I have recently gotten my sink installed with the Hyco Handyflow Undersink. It works great and makes the water go hot. However when I turn it on to heat the water, it causes the tap to slowly drip. When i turn this off, it seems to stop dripping.
Would there be any indication what the problem is from anyone?
Sounds normal as the water is expanding when upto temp does it stop dripping ?
The Hyco is supplied with a vented tap, so it will drip to relieve expansion when turned on.
If thats just a “ normal “tap it doesn't sound right , post a pic of the pipework under the sink
I had to make an account to get the picture functionality working.
I'm not too sure how these work, so if this is normal then great! I don't know how long estimate it will take for the dripping to stop, i shall test that out now.
Here are the photographs
I've just had the heater on, and after about 10 - 20 minutes it's turned off, the dripping has stopped and the water is heated!
So my lack of understanding is my failure! As people have said, it's normal due to the vented tap and expansion of water. Once the water is heated, it stops the dripping stops also!
Sorry for the silly question!
Make a sign up to tell as it’s common for people to try and keep turning the hot tap as it’s dripping and it breaks the tap
Reply to Hyco Handyflow Undersink, When turned on, causes tap to drip in the USA area at PlumbersForums.net
I have a Bristan Manhattan mixer tap in the kitchen. Five years ago, it started to drip. I replaced the valve in the cold water side and the...
I recently read a post / comment whereby there was a recommendation that if you are away from your home more than 24 hours, then you should turn...
Hello all, first time poster so if there is any additional information I can provide that may help, please let me know. Our kitchen mixer tap has...
Hello all, The kitchen sink in the property we are renting drains really slowly, and I was hoping to remedy or alleviate this with some educated...
I have a problem with noise and vibrations from my shower when i first turn it on. The problem lasts for about 30 seconds after the shower is...
