Discuss I have a nu-heat UHS installed in 2006. Recently I’ve noticed a dark orange coloured substance appearing in 2 of the flow in the USA area at PlumbersForums.net
Can anyone help me identify the cloudy orange contaminant and suggest a remedy?
It is corrosion caused by oxygen in the heating system it needs flushing out throughly and a quality biocide chemical treatment added like Sentinel x700 . Kop
Why is it so much worse on two of the gauges?
The left gauge takes 4 litres, the right one takes 2.5 and the middle 2 are much lower flow. I’ve hardly had the system on since I noticed it in case I worsened a problem that might be resolved better if I didn’t. Thank you very much for your comment. Do you have an idea where the corrosion is coming from? The boiler does gurgle for a few seconds after starting up.
Thank you very much for that reply. Do you know where the corrosion comes from? The oil fired boiler does gurgle for about 4 seconds on initial start up.
Your oil fired boiler is just a steel jacketed box with a burner firing into it, the combination of steel and water and heat without a corrosion inhibitor added will cause rust and sludge to form in the system, your system is long overdue a water change and chemical treatment this should be done every 5 years as a rule Do you have a service agreement ? when was the boiler last serviced ? it is now part of a service to check the water quality and pH level and address any issues found . Regards Kop
Thanks for the info Kop. My boiler is serviced annually but I’VE never been able to get a plumber very interested in servicing the UHS though items have been changed when they’ve been malfunctioning. The boiler feeds both the UHS and upstairs radiators and I’ve checked that the corrosion inhibitor appears to be okay in the rads and the radiator water shows clear. Sentinel X100 is used but I wonder if this suits both the steel rads and the plastic UHS? Any idea what might specifically cause the contaminant in the UHS without discolouring the rad circuit?
The suggestion to use X700 as well is that while X100 will work as a corrosion inhibitor, X700 will prevent bacterial growth at the low temperatures found in the UFH section of your system. I'm not sure exactly what that has to do with the rust (on the gauge springs?) however, but I suppose there is the possibility that the brown is some form of bacterial growth.
Reply to I have a nu-heat UHS installed in 2006. Recently I’ve noticed a dark orange coloured substance appearing in 2 of the flow in the USA area at PlumbersForums.net
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few...
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I...
Hi, My current hot water system needs to be replaced. Anyone got any suggestions or can recommend any plumbers around Derrimut area that won't...
