Discuss Ideal Classic FF250....How do you drain the system? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a Ideal Classic FF250 fitted in the loft to replace a back boiler this was fitted in 1999.
I want to drain the system so I can replace a radiator and new TRV's.
Boiler is in the loft with cold water tank, also next to the boiler is a small red expansion vessel with gauge set a 1 bar, the grundfos pump is there as well and a small NRV at the top.
In the airing cupboard a new green Albion hot water tank was fitted, and a sunvic three port valve, the filling loop is also there and another gauge set to 1 bar I have never known it so move either up or down.
I was also toying with the idea of replaceing this boiler but it has been so reliable only one breakdown and that was the fan on the top it seized, sprayed with lubricant and been fine since, but it does sound a bit noisy I guess the bearings are on the way out.
1. Advice on how to drain and refill.
2. And should I keep/replace my boiler.
If pictures would help let me know.
Thanks in advance.
In terms of draining you should have drain points on ground floor, under radiators, is one place to look, also have a look out side could be installer fitted an external drain point, refilling is done via the filling loop in airing cupboard.
No because you have a sealed system, but look for any other drain points especially if each ground floor radiator is on separate drops, don't forget to add an inhibitor back into system when refilling
Thank you for help, I'll replace the radiator when the weather warms up a bit in case I hit any problems
Reply to Ideal Classic FF250....How do you drain the system? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
I’ve had an Ideal Vogue 32max/gen2 system boiler to a Megaflo fitted a week and running it at Flow temp 73 degrees to getting a return temp of about 55 degrees C, I’m seeing the LCD screen saying the efficiency level is only 25-28%. Has anyone else seen such a low percentage? I know for a fact...
Hello friends - I really struggle to understand my heating and hot water system I posted my question on Diynot but it ended up being five pages and couldnt get to the bottom of it and I thought worth asking the elders on here for their view - Hot water temp is 40 Degrees - Ideal Mexico 2...
Hello everyone, Baxi Ecoblue System boiler which was recently serviced just before Christmas. There has since been a constant but slow drip coming from the black nylon plastic drain plug at the back of the boiler which is accessible from the underneath. It does not appear to be from the thread...
I have been facing central heating low pressure on unvented hot water RM Cylinders but can't see any leak on the PRV, expansion vessels and plasterboard celling. I have got unvented pressurized RM Cylinders hot water system with 27KW Worchester gas boiler with expansion vessels . When...
losing pressure
L
Hi All This is following on from thread I made a few days ago but can't seem to find I'm in a bit of a bind with my CH design where I want to sort all of my rads and do some other bits including fitting a filter but I'm stumped on how to drain down due to how the system is put together...
