Discuss Ideal HE30 L-F fault in the Plumbing Jobs | The Job-board area at PlumbersForums.net
V
Videodoctor
Hi, I have an Ideal HE30 which is displaying the L-F fault. I have measured only 110v dc at the gas valve(instead of 200v i believe) and there is no voltage going to the igniter module except for near the end of the sequence when 200v flashes up for about a second.
The boiler goes through its starting up procedure with the pump running,the top fan running etc and the circuit board can be heard making all sorts of clicking relay noises.The board is the orange type.
My hunch is that's its the circuit board that's causing it but have any of you guys any ideas as to other checks i can do before ordering a replacement.
Thanks for your help.
Regards.
Probably a fault other than the PCB. But as your not gas safe, we can't give advice.
May as well close the thread, he`s gone to DIY for help.
anyone on there if so post this link :D
but fill in the blanks :)
/diy/threads/diy-gas.8090/
Reply to Ideal HE30 L-F fault in the Plumbing Jobs | The Job-board area at PlumbersForums.net
