Discuss Ideal Logic+ 30 Combi Fault in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Basically, the boiler this morning wouldn't fire up so went to check it and was the pressure was 0, so topped it up normally to about 1.5 which has worked before, but it is still giving the fault:
1) top pressure up to 1.0, 2) bleed radiators, 3) call installers
I've had a local plumber out who tried to reset it and get it to fire, but didn't have any joy - he thinks maybe it could be a sensor not recognising the pressure is high enough? Called Ideal who's soonest response time was Friday, so hoping someone could point me in the right direction to get it fixed sooner
Have you tried turning the power off and leaving it 5 mins then back on ?
try topping the pressure upto 1.5 bar
Try resetting again but just go to reset and back , don't hold it over for long
Thanks, topped it up and its about 1.7 now, and did another reset but it still sits on the fault - it sounds like it's trying to fire up and the fan goes
Gas safe engy needed or idea sorry to say
Heating and hot water not working?
Have you got gas at another appliance?
The Ignition units can play up on these a good warranty on the Logic + so should be a free fix providing the servicing is up to date. Cheers kop
Reply to Ideal Logic+ 30 Combi Fault in the Plumbing Jobs | The Job-board area at PlumbersForums.net
