Discuss Ideal Logic Combi ES38 No control in the Central Heating Forum area at PlumbersForums.net
Hello,
I have a Logic Combi ES38 Boiler and for some reason, it's ignoring the commands from the thermostats on the wall, for example, both thermostats are set to off but yet the boiler is still on, I've tried the following:
  • I've turned it to just water and not radiators no effect.
  • Changed the batteries in both there thermostats on the walls
  • Cleaned the connection pins on the thermostats.
  • Switched them on and manually tried changing the temperature.
If there is anything else I can try please let me know as I'm a bit confused why it's happening.
Its serviced every year and each time it's fine and like new so not sure if this is a fault or maybe its something that's worn out over time.
Cheers
WW
Had it on a three port valve ? What do you have fitted . Kop
2 circuits upstairs and downstairs , the upstairs is fine its the downstairs that seems to be going for it.
Forgive me if I'm unsure of the lingo :S
Cheers
[automerge]1586115719[/automerge]
Both thermostats? Sounds like there is a two port valve somewhere that's giving a permanent live to the boiler.
Yes, I've set them both to be off, swapped them round, replaced the batteries but still for some reason is stuck on what I'm guessing / feels like 24
Reply to Ideal Logic Combi ES38 No control in the Central Heating Forum area at PlumbersForums.net
I've got a 2016 Logic PLus Combi 30 and a Salus RT505TX RF Thermostat The thermostat seems to keep losing connection, no matter the placement. It...
Hi I am somewhat confused. My daughter has a combi boiler bought 2-3 years ago and has it timed to come on in morning for an hour and at night...
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised...
Hi, As per the thread title, I have an Ideal Logic Combi 30 and I am having a problem with the pump, which keeps activating without any DHW/DCH...
1K
