Discuss Ideal logic + Heat 18 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Afternoon all I was just wandering if the Ideal logic + heat 18 has a build in frost stat.
No they don't best to fit an external one, only problem is you need to be gas safe
No its not insulated. The boiler is in the garage. The garage is a new build. So not likely to get cold in there. But iv heard it's always best to have a frost stat if the boiler is outside the house.
Might invalidate the warranty on the boiler if you do not have one.
Ok great stuff. Just out of interest is the boiler in danger of not working if the garage gets a little chilly in the winter. Not Frezzing just cold.
How do you know it wont get to freezing temps?
Obviously you are wasting heat through non insulated pipes
As above, but I would get someone in to quote you before you decide it is a definite NO.
Only say it won't be Frezzing in there as it's a well insulated garage. Sorry the pipes going into the boiler are Insulated but the gas pipe is not. All this is in the garage. Hope that makes sense.
Sorry not read all above , you dont just insulate pipes to prevent freezing its also to prevent heat loss .
Ok thanks for advice. Only asked original question. As someone on the Web said it had a built in frost stat. And as they could not see an electrical connection for the cable.
Reply to Ideal logic + Heat 18 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Fitted unvented hotwater cylinder building control looking forms signed it off job was in england i am qualified northern ireland send out a form to fill in what do u need to sign off in england as building control said they dont give out forms like they do in northern ireland
