Discuss Ideal standard push Btn flush valve in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
wiggers
Hi all, I am trying to find an alternative flush valve to fit the cradle of a ideal standard push btn flush.
It is all tiled in and changing to a Siamp or fluidmaster is not an option anyone have any ideas
Could you convert it to the air one as that’s still being made / available and fits on the same frame ?
A Siamp Optima 49 or 50 is an ideal swop for this discontinued flush valve. Over the last few years working in social housing I’ve replaced a lot of them.
They don’t fit on the existing cradle tho so they ?
No, it's a complete replacement. Also the Ideal syphon comes in three different sizes, 180, 200 and 225mm. Make sure you get the right size.
Op can’t do that as it’s concealed
Reply to Ideal standard push Btn flush valve in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi all Noticed bad smell in my drain out side put my hand down and it unclogged it for now however I checked my sewer drain and after flushing my...
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
Hi Does anyone recognise the make/brand of the radiator valve. It leaks when closed and Iam hoping I can replace a seal etc?
