Discuss Incoming gas pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
Richo106
I am in the process of converting my integral garage and the Incoming gas pipe from the metre is on a wall that needs to be plasterboardsd, I was going to use 38mm battens to space the plasterboard off the wall to miss the pipe. Is this legal/within the regs? Is there another way of doing this?
All help greatly appreciated
You need to seek a Gas Safe Engineer who can come and advise you on site, there are lots of issues with what you are proposing to do which can't be fully addressed here & yes they are covered by the Gas Regs (Law)
As above. You need advice. If your boxing gas pipe in a void there are specific regs re ventilation requirements and more....
Call in an engineer.
As above. But you are correct to ask, we just can't answer you.
Thread closed.
Reply to Incoming gas pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Had conventional boiler and tanks removed last year and new combi fitted and just recently had it serviced but the guy who did it has given me a...
Hi everyone, Just a query about what size in KW gas combi boiler do I need for a top floor flat (3rd floor). I have a Vokera Easi heat plus...
Hi all, can anyone hell me identify this pipe is it for gas? Property is all electric but the flat below and flats next door have gas boilers. The...
All, Belfast, Northern Ireland. I am in a bit of a predicament. I have recently had a stove fitted in a chimney that had a disconnected and...
