Discuss increase pipe size in the Plumbing Jobs | The Job-board area at PlumbersForums.net
spanner
Hi lads.
Just realised I'm about to remove a Potterton combi which has 15mm gas feed.
A MAIN combi going for installation and the pipe size is 22mm
Pipework is totally concealed atm and there's about a 1500mm of 15mm accessible pipe run to the old Potterton
Is there such a fitting or a solution.
I can quite easy understand if it was the other way round
Do have to upgrade the pipework from the meter all the way to the boiler?
There is sufficient gas supply from the meter which is about 2.5meters away.
It has 26 mbars standing pressure and a 20.5 mbar working from the meter.
There was a cooker which is capped off and cooking on electric.
No other gas appliances in the place.
Cheers
Spanner
You were never going to get sufficient gas down 15mm for a combi.
Seen loads of combi with 15mm pipe and perfect working pressure from meter reading to combi before!
Just this is awkward it has 22mm from the meter then under flooring and up in 22mm. Which has a run of 1200mm from the wall
Sounds like it'll have to be
You will only know the drop for meter to boiler once it's fitted unless you can test the existing.
What size combi are you fitting?
If it's only 2.5 meters from meter to boiler you may be lucky
just change the 1.5m to 22mm then test pressure.
i think it will be ok.
Reply to increase pipe size in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Non-professional / knowledgeable person here. I'm a Brit in Romania who volunteers for a charity building an old peoples home for needy old people. Out here competence and integrity is harder to come by in a worker, in fact it's hard to find workers at all where we are in the countryside...
British Gas servicing the above boiler ramped up the boiler to maximum in the installer menu to do flue gas analysis. They also measured the working gas pressure on the gas valve test nipple. This fell to 8mbar on maximum and 17mbar on high setting. They then removed the isolation valve under...
Hello, I have quite low flow rate for my electric shower (a piddling 5L/min), and would like some tips or advice about how to solve or find the cause. I would like a flow rate of about 12L/min. Here is my set-up: Standard gas boiler (not a combi) in the kitchen, have cold water tanks in the...
Essaboy
E
Hi guys question about saniflos đź’© I'm working at a property that the entire place was fed off a sani, that's packed up, blocked the line entirely and they've urgently had to get me to replace and make some changes, initially I was going to install a sanivite for the kitchen sink separately...
Hello, bit of a noob question but would someone be able to help me to understand the pipes coming off our boiler. It's a Grant oil combi boiler, and where the pipes come in is in a room at the front of the house. I am about to box them in but I really wanted to understand what the various pipes...
