Discuss Inline scale inhibitor in the Plumbing Jobs | The Job-board area at PlumbersForums.net
helpsy
Hi all
Just wondering if any of you have any experience of supplying/or fitting inline magnetic or electrolytic scale inhibitors.
Your experiences/opinions welcomed.
hi,
i was at the phex at old trafford last week and saw some of these in action. the one that seemed most impressive was the spirotech. slightly dearer than the sentinel or fernox etc.
they do a conbo valve that bleeds air as well. they had clear pipes with water and a pump added magnetite and air, cleared in no time.also versatile fixing. 20year gaurentee!!!!
i'll be using these in future.
if retro fitting to a system you will need to re-visit after a month or so to drop the crap out, then should be annually after that.
KJ
I was refering to the incoming mains supply line.
Cheers anyway.
Hi all
In my experience they are all carp and only fit on a new install to comply when I have to. Water softeners are the best way or if cost is an issue then a combimate or something like this.
Reply to Inline scale inhibitor in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
Hi all, as the title says, few months ago moved into a house where the water is way harder than expected. We did not expect it because we lived in...
2K
Hi, I'm in my new build 2 years and the shower pump has died. I have an air to water unit downstairs is in the utility which I've been told is...
Hi, DIY homeowner here. Ist floor of house. Front bathroom hot water draws from cylinder which is heated by the Greenstar 28i Junior Combi...
Hi, Short version: Do frost protection valves trigger when the water in the pipe gets to threshold, or when the air temp drops? Long version...
A bit of history first. 2 yrs ago visited a grant boiler with boiler and pipework kettling. I added SentX200 noise reducer. It is standard open...
