Discuss Intergas Boiler pressure dropping in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
N
NetihV
Intergas Boiler (only 2 years old and serviced each year) pressure dropping to 0b after just 1hr of running - can anyone help? No leaks anywhere
Check the pressure after running and see if it increases from say 1 bar to 3 bar, if this is the case (sound likely) then you might have a blocked communication hose from boiler to expansion vessel. That or your prv could be passing.
Reply to Intergas Boiler pressure dropping in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
PSxxxxxx
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few...
