Discuss Internal fuse potterton assure 30 boiler in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
My boiler, which is 3 years old, has stopped working and it turns out it was the fuse.
I had an engineer resolve the issue, but when I turned the boiler off then back on it stopped working.
The fuse that was used was anF2AL250V, that's .2A
Should it have been an F2AH....?
Also, is it 2A or .2A?
TIA
Dave
why turn the boiler off?
it could be the dhw/ dhw ch switch is at fault. isn,t your boiler on a stat?
i have not turn mine off in 8yrs. as there is no need,
2 amp should be fine.
I just happened to do that is all.
I'm not in any way a plumber and wanted to ensure I'm using the correct fuse as I'm changing it myself.
So .2AL is ok to use?
I have ordered some F2AH fuses.
Apologies, please excuse my ignorance, I've no idea about dhw ch or stat.
it is an almost new Potterton Assure 30 combi boiler.
Potterton Assure Combi. 25. 30. Nominal heat input central heating — Maxi mum rate. Net (Qn Hi) ... External fuse rating. Amp. 3. 3. Internal fuse rating.
hope that solves your problem
If it's almost new, the boiler should be fixed under warranty by the manufacturer. A newish fuse blowing is not a fault in itself, it is a sign that it's doing its job protecting the supply from a fault elsewhere.
Reply to Internal fuse potterton assure 30 boiler in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I...
  • Article
