Discuss is there such thing a different toilet sizes?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
beesley121
hi guys,
Ive done a couple of jobs latel and had problems fitting toilets the customer had already bought before they give me the job.
one job i did had the soil pipe at the back of th coming in from the left, it was then elbowed towards the toilet and then a pan connector was pushed onto this. This pipework was all boxed in and the original toilet fited in well. The toilet the customer bought had a smaller 'neck' which ment that when the toilet was pushed back as far as it would go, the cistern did not make contact with the wall, this ment it could not be fixed to the wall as it was 2.5 inches too far away
today went to a job, soil coming straight up through bathroom floor. customer had BTW toilet but had bought a bog standard toilet (old style). the middle of soil pipe was approx 6.5 inches from wall. This ment again that if the toilet was pushed back so cistern could be screwed to wall, the base of toilet overlapped the soil pipe so no chance of fitting that toilet there either.
now i need to find a toilet that will replace the orignal toilet for this job but i just dont know what to ask for in order to make sure that the cistern will fit flat to wall and waste on toilet will be far enough away from soil waste for me to get a pan connector on it
i hope you guys get what i mean but when buying toilet, there are no dimensions, so what do i do?? i totally stumped by this one
Low level cistern and pan, connected with a flush pipe. You can get a longer flush pipe if needed. B25010_wpdp.jpg
As above, but you can get swan neck flush pipes as an option if space is really tight. I prefer these in boxed in cisterns.
Is it a close fit toilet?
Yes, close coupled. You can't use this kind of toilet as its designed for pipes which come through the back walll. You need a low level one as ecowarm stated.
Mainly what I would do is if the distance was only 2.5" as you mentioned, I would use 2 cuttings of chrome pipe to act as a spacer between the back of the cistern and the wall. Use a longer screw and screw it up until the spacers are tight to both the cistern ad the wall.
Saves having to alter any 4" soil pipe. Other instances I would do is use a "Goose-neck" multi-wick! Something like this
Lets the toilet go back a little further to enable the cistern to go onto the wall
Reply to is there such thing a different toilet sizes?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, I'm seeking advice on resolving the persistent blockage issues with my downstairs toilet. A year ago, I replaced an 80s close-coupled...
I had a plumber in to replace my old pan connector as it was leaking due to the wax deteriorating. Now when this toilet clogs up (which is a...
As part of a slow DIY bathroom refit I've removed the old toilet from the original location next to the soil pipe (and obviously capped off the...
Hi! Totally inexperienced DIY newbie so bear with me for descriptions! Pictures hopefully help. Iā€™m trying to remove an unused downstairs toilet...
Hello All, Was looking for some innovative ideas from you all.šŸ˜Š Iā€™m renovating a bathroom in a flat. The soil, hot & cold water pipe runs stops me...
