Discuss Is this a job for the pro’s or a job for a competent DIY guy. in the DIY Plumbing Forum area at PlumbersForums.net
What do your books say? 🤔😉
If you’re only changing like for like, then pretty much anyone who’s into diy can change one. If it’s altering pipework, this is where it can get a little more skilled. I haven’t watched the video, but one tip would be to count the number of lockshield turns on and off, so as not to upset the system balance.
Also mark the bottom of the old radiator with a pencil, so you know where the bottom is before you remove the radiator. Then it's easier to hang your new brackets.
Thanks for the advice. these type of radiators come with these brackets, what’s the easiest way to mark the wall to hang these? Some one must have a technique lol.
You may also need extension tails as radiator sizes have changed, also get some blanking plugs temporarily in case the valves let by.
I needed a 3/4 washing machine blanking plug for mine, yours may be different.
Measure and level the top brackets and hang the rad then mark the bottom ones once level and happy
Reply to Is this a job for the pro’s or a job for a competent DIY guy. in the DIY Plumbing Forum area at PlumbersForums.net
Fitted unvented hotwater cylinder building control looking forms signed it off job was in england i am qualified northern ireland send out a form to fill in what do u need to sign off in england as building control said they dont give out forms like they do in northern ireland
  • Article
A Plumber Who Worked Illegally Gets A Suspended Sentence After Falsely Claiming To Be Gas Safe Registered. A Plumber in Herefordshire was prosecuted after Hereford Trading Standards Team found that he was falsely claiming to be on the Gas Safe Register when he was not, putting members of the...
