This is my first post here and would really appreciate the help.
I realised last week that we have a mouse or rat problem and whilst waiting for my traps to be delivered the little bugger has gnawed through a plumbing fitting! Awoke this morning to the sound of spraying water behind the kitchen units. I turned the water off and finally managed to find where the leak is. Although I'm a little unsure what type of fitting it is. The majority of the fittings are push fitting with screw ends that should be relatively easy to replace whereas the one that has been eaten is a plastic right angle with metal caps - I'm unsure if it is a push fitting (image attached). The one that has been eaten is actually the one behind in the shadow although they are the same. Any idea if this fitting can be easily removed so that I can replace it with a similar push fitting with screw caps?
Cheers, Ryan.
Cheers, Ryan.
