Discuss Is this becoming more common or just my imagination? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
WaterTight
Subscribed
As a disclaimer I just do small maintenance in wet plumbing. So I'm a bit limited in overall knowledge and skillset and will get lost if things get overly technical.
When I started 6 or so years ago everyone seemed either to have a combi for heating and domestic hot or a vented system with a couple of tanks in the loft and a cylinder in the airing cupboard.
Now more and more I've found people will have the system split one way or the other. So they may keep the cylinder for domestic hot but have a combi installed just for heating. I seem to see this more and more. Is there a good reason for this and is it likely to get more common?
Also, does this mean the coil going through the indirect cylinder is now mains pressurised? I guess it must be.
normally combi and unvented cylinder as there is more than one bathroom/ big bathtub
and normally after they have had a combi installed they find out why there not very good for more than one bathroom
The coil on the cylinder will just be linked to the heating system, - not the mains hot from combi.
Would it not be pressurised to 1-1.5 bar ish though? Like the heating circuit off a combi would be normally?
Is this more and more common or is it just my local area doing it for some reason?
Yeah I've seen few Combi's with hot water from the Combi to the kitchen tap or kitchen tap and cloak room toilet then cylinder either unvented or vented
had a good one where the Combi's heating side was open vent so the pressure in the boiler was 0.6 constantly
Just changed one like that old wozzie out which had heating fed by tank in the loft
/\ This is part of the problem.
I used to know how to work out what system I was dealing with before I'd passed the front door. Now I need to go looking. Last place I had to go into the loft and the garage before I could work it out.
Reply to Is this becoming more common or just my imagination? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Afternoon. I have an issue with no water flow from any of the hot taps in the house, I can't seem to find a solution to the issue. System is a...
Hi all, We're looking to update our existing central heating setup and wanted to get a few more opinions. We currently have an open vented...
T
Hi We urgently need to get our h/w cylinder replaced because it's leaking. Our current system is oil boiler feeding underfloor downstairs...
I have just had a boiler, hot water tank and power shower pump replaced on advice by my plumber. I have two separate boilers, heat/hotwater...
Hello friends - I really struggle to understand my heating and hot water system I posted my question on Diynot but it ended up being five pages...
