Discuss Is this my HWC drain valve and where does it go? in the USA area at PlumbersForums.net
Hi
I might need to part drain my HWC to fit a new Essex flange washer and I posted an earlier message thinking I did not have a drain valve , however I have noticed a valve connected to the cold supply which , if the cold supply is isolated , looks like it will drain the tank .Please check the images
If so , where is the water going to drain? The pipe just disappears downwards and I am wondering where the pipe is likely to go?
If this is a drain valve , do they normally do this?
Yes by the looks of it yes
Under the floor / outside or maybe to drain
Reply to Is this my HWC drain valve and where does it go? in the USA area at PlumbersForums.net
Hi, I need to drain my vokera 29 boiler in the attic as Im going away for 4 weeks at least to make sure there are no frozen pipes. In my small...
Hi All This is following on from thread I made a few days ago but can't seem to find I'm in a bit of a bind with my CH design where I want to...
[ASIDE: I did wonder if this was the best forum for this but figured as it was a boiler related issue that the gas engineers would be dealing...
Hey All-- New here as this is something I have not had to do on this scale before. I am renovating our laundry room, which currently only has the...
Hello. I am planning to build a small half bath in my garage, next to a washing machine, using old showers plumbing. There was a stand-alone...
