Discuss Isolate water to heating interface unit (HIU) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi there. I'm trying to work out how to isolate the water in my flat, so I can fix a leaking shower tap. My flat has a heating interface unit (HIU), which is being fed by various pipes - see photo. I'm not sure though what pipes I should / can isolate to stop the flow, can anyone provide any advice? Cold water is simple, there is a lever labelled for 'cold water isolation valve', which works fine. However, there's no equivalent for hot water, and I'm a bit worried about just turning them all off as there's quite a bit of pressure in the system. I can't find any valves on the pipes leading to the shower to isolate, so I need to do this centrally. Thanks for any advice.
2nd from the left
Red tap label
Left to right
Cold water in
Hot water out
Main boiler flow in
Main boiler return out
Rads flow
Rads return
Reply to Isolate water to heating interface unit (HIU) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
Hi, we have an HIU unit, which we only get hot water from the taps when we turn on the heating unit. A number of engineer have come in to check...
Deleted member 120897
Hello, I am fitting new taps and a shower mixer in my en-suite and was looking to isolate the hot water pipes. I have an unvented indirect...
Hi Just had a new bathroom installed with a toilet bowl that reaches the back wall. Its has a bottom entry cold feed to the cistern. The fitter...
1K
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
We have had an ongoing issue with low hot water temperatures in a school. During the recent repair of a leak, the plumbers isolated the hot...
