Discuss Isolating valves and drain points in the Plumbing Jobs | The Job-board area at PlumbersForums.net
More often than not when I go to do any work on a domestic system there’s no way of isolating what I want to work on so end up having the drain the system. To make things worse it’s surprisingly common there’s nowhere to drain the system.
Do other people find this too and if so why do you think it’s the case?
All the time. Laziness.
It does kind of make business sense too, more often than not it’s the person fitting a system who would be called to maintain. If it takes 3hrs to drain, change a part and refill rather than 1hr to just close a couple of valves and change a part you can charge significantly more.
The optimistic side of me would like to think it’s to avoid leaks but the cynical side of me says it’s maybe laziness as you say.
I think if you’re canny most if not all changes can be done without a full drain down. Yes isos and lever valves make things easier but unless you’re doing some sort of heating control panel with pump and valves mounted more often than not space won’t allow or the customers budget
You think 'you're' cynical? Learn ;)
In my experience, it would be rarer than rocking horse poo for a plumber to think in such a convoluted business sense.
It is, as already explained, either 98% laziness or 2% cost. On installs where I've found it, it's always been part of a spec (so one specific estates etc). Personally, I've installed them justifying the cost of doing so by explaining how the next occurance of a drain is far quicker & cheaper...
Just don't forget to:
- coat the washer face, when it's reinstalled after soldering, with some silicone grease so it doesn't stick quite so easily
- nip it up so that it doesn't leak at 3 bar only. If you wind it up you'll not be able to get the bu66er out. :)
The majority of plumbers , not all , may do a one off job and will probably never return so they simply cant be ar*ed .
Anything I instal , I always think how do I maintain this if I or someone else has to come back
I’m surprised at you’re experience of jobs largely being one offs. Possibly a good explanation for it.
Reply to Isolating valves and drain points in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello Plumbers I’ve replaced a 540mm high cast iron rad with 740mm high, like for like but still a 20mm valve extension was required. All was...
Hi All This is following on from thread I made a few days ago but can't seem to find I'm in a bit of a bind with my CH design where I want to...
Hello guys, a couple of months back I installed a new shower and sink into a part of the house that hadn't previously been plumbed in. This forced...
[ASIDE: I did wonder if this was the best forum for this but figured as it was a boiler related issue that the gas engineers would be dealing...
Hi, I need to drain my vokera 29 boiler in the attic as Im going away for 4 weeks at least to make sure there are no frozen pipes. In my small...
