Discuss Isolating valves and drain points in the Plumbing Jobs | The Job-board area at PlumbersForums.net
It's the that will do attitude and laziness of price jobs. Then lack of investment from home owner. Most when you say give you the impression it a great idea to add isolators and a drain off point, but never do jack about it.
plumbing is largely unregulated
so there is little standardisation
anybody can play, and do,it as badly or as well as their price or whim takes them...even on new builds ..which can be worse
centralheatking
Once you have an agreed price with the customer, then every part you use comes out of your potential profit, - so greed is also a factor
More things to leak, the quality of parts has gone downhill as the suppliers and manufacturers compete. Pump valves leak when you use them, gate valves stem snap, isolator valves weep,
Dammed if you do, dammed if you don’t
I’ve found in when changing zone valves, float valves, taps etc. The only part that always seems to be fitted with isolating valves are circulating pumps.
Float valves to any cistern is a water regulation, so hope you fit them? A lot of things like taps are just considered good practice :)
and nowadays quality is not an issue,just price and speed. and the churn is a factor, churn is loads of newbies coming into the market undercutting and going bust to,be replaced by more failures and it goes on
centralheatking
I tend to fit them anywhere I can.
I’m not sure you’re right on the water regs, my understanding is they “should” be fitted to float valves. Where “should” is used in regulations it’s considered advisory rather than mandatory.
They use the word “shall”, I take that to mean mandatory.
Reply to Isolating valves and drain points in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello Plumbers I’ve replaced a 540mm high cast iron rad with 740mm high, like for like but still a 20mm valve extension was required. All was...
Hi All This is following on from thread I made a few days ago but can't seem to find I'm in a bit of a bind with my CH design where I want to...
Hello guys, a couple of months back I installed a new shower and sink into a part of the house that hadn't previously been plumbed in. This forced...
[ASIDE: I did wonder if this was the best forum for this but figured as it was a boiler related issue that the gas engineers would be dealing...
Hi, I need to drain my vokera 29 boiler in the attic as Im going away for 4 weeks at least to make sure there are no frozen pipes. In my small...
