Discuss Issue with new vokera vision 30 and thermostat. Help ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
F
foxyuk13
Heating system fitted with Salus Rf thermostat. The boiler still has preprogrammed times on clock however heating guy said easing operating through the twirl wheel for my tenant.
Thermo is down at 5 degrees but heating still coming on at the manufacturers preset times I have contacted
Salus and done a few re pairings but still has mind of its own
heating guy says could be someone else ie neighbour with same unit and interfering this possible ?
At mo central heating is at hot water only Not much good
Any knowledge or advice
Sounds to me like it's wired up wrong. Would checking that before anything else
Can rule out pairing with neighbour by removing tabs on the back of the thermostat and repairing. Personally it sounds like the wiring has been completed incorrectly
Think will need to get the Siemens rdj10rf installed as I had 3 years no issues before upgrading to hive
Reply to Issue with new vokera vision 30 and thermostat. Help ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
