Discuss It's Bank Holiday Monday, so obviously my boiler breaks in the Plumbing Jobs | The Job-board area at PlumbersForums.net
H
Hectic
Hello
As title really. The boiler - a Ferroli 701 - decided yesterday not to fire after calling for hot water (the pilot light was lit). As I'm a bit of a techie, my approach of switching something stuff off and on again spills over into other things. Anyway, once I had done that, the pilot light decided not to ignite at all. And that's pretty much it.
I followed the reignition instructions carefully (I've restarted the boiler before, so I can categorically say it's not me doing something wrong as far as that is concerned). I have also checked the PCB and it's showing no error codes and appears to suggest the boiler is operating as it should. I have also inspected the PCB for problems (I understand from reading around relay 4 is the most likely culprit) and that appears to be fine also.
This leads me to conclude I have no idea what the problem is. I did think faulty gas valve, but prior to switching it off, the pilot was (and had been for two months when the boiler was last serviced) fine. Could it be a faulty ignition? If so, what's the damage?
It's time to get a gas safe registered engineer in to look at it for you. Could be any number of different faults which only someone gas safe registered is qualified to repair.
Hectic , welcome to the forum looks like you've done what you can as mike said you now need a gsr engineer , try putting a post in the I need a plumber section maybe a member on here is close to you
Reply to It's Bank Holiday Monday, so obviously my boiler breaks in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Context for issue: Last winter the temperature switch on my boiler shorted somehow, the boiler was then running WAY too hot and ended up...
Context for issue: I'd like to start by saying I'd rather not read 100 "Hire a professional comments", I will do that when/if it comes to it, but...
Butchy10
My Grant combi oil boiler is giving me quite a headache at the moment. When I returned home last Friday I'd no heating or hot water. An engineer...
Conditions: nearly 10 year old boiler WB2B, heating mode off, DHW on or also in standby, Boiler shows no fault LED on, no new fault logged, room...
Hi, Have a Valliant Ecotec Plus 637 system boiler that is showing no error codes and S.0 (no demand for heat), but it is not heating. Have...
1K
