DIY Bob
I've learned a lot from this forum over the last few weeks:-
- I can wire a spur if I've got Part P, but I can't connect a boiler
- I can connect a boiler if I'm Gas Safe, but I can't fit a spur
- I can fit a compression fitting, but I don't need PTFE tape
- I mustn't use lead solder on potable water
- I can fit a bath mixer, but I need a check valve on the cold main incomer
- Don't fit a bath mixer if the cold is fed from the main
- I can get a bath out by jumping on it
- A Grohe shower is great/okay/rubbish (please delete as appropriate)
- When using a yorkshire fitting, apply heat to fitting/pipe (delete as appropriate)
- Don't use laminate flooring in bathrooms (doh!)
- Keep away from National Utility Solutions (like the plague)
- DIYers shouldn't deal with Stuck Cocks
