- Messages
- 34,373
- Solutions
- 2
Would need a pic
Discuss Jet Range by Wolseley - DN20 Isolation Valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
So why could he not use a 3/4 olive?Trevor,
DN20 is an ISO sized fitting for 3/4 inch pipe (26.66mm). It is not intended to be used with 22mm pipe. With respect to copper pipe it is intended for 3/4 inch outside diameter.
Normally if metric and imperial fittings are mixed up with 15mm and 1/2inch diameter pipe they generally work (not always). However the size difference between 22mm and 3/4inch is too great for success to be a possibility.
This would account for the pipe “popping” out - but I would be surprised that the pipe remained in place and leak free since the original installation - unless it had been “mumified” with ptfe tape!!
The Jet valve in question is a non return valve, the screw is for testing, it is not intended for isolation, there should be a proper (ball) isolation valve at the point of entry into the boiler house - the installer will have fitted one - he/she won’t have driven 1/2 mile to isolate the supply.
The flexibles look to be a makeshift filling loop. They should be replaced with the correct WRAS compliant ones.
If I were in your shoes, I would check out the system on a line by line basis, both for the design ( heat balance and flow calculations) and the specification of pipework and fittings / quality of installation work.
Reply to Jet Range by Wolseley - DN20 Isolation Valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
