Discuss Keston Qudos 28s boiler AR or ID? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi there,Just need to check with the experts here the boiler in question passed flue analyser tests. However the exhaust tube is rusted. There is no replacement available as the model and parts obsolete. Any advise will be greatly appreciated. Thank you
Me personally ar only because you can see condense has run down
Only id if when you test them with your fga you start to get readings
Thank you for your response Yes the fga test came fine I wanted to double check here. I wanted to change the flue exhaust however there is no availability. Will recommend customer to change the boiler.
Reply to Keston Qudos 28s boiler AR or ID? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few...
