Discuss Kettling ideal classicFF in the Central Heating Forum area at PlumbersForums.net
My boiler keeps kettling even though stat is right down, 2 plumbers have both flushed and chemically cleaned system. Could it be the pcb
ideal classic is cast iron heat exchanger so could just be weak spots in that you may not be able to remedy, whereabouts are you could it be limescale build up if so try a boiler silencer eg sentinel
Reply to Kettling ideal classicFF in the Central Heating Forum area at PlumbersForums.net
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
Sonya K
PSxxxxxx
