Discuss Kitchen monobloc swivel spout tap went to turn n hot tap and nothing no water at all in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Re: Kitchen monobloc swivel spout tap went to turn n hot tap and nothing no water at
Is it air locked on the hot side? You need to give us more information, more on the plumbing system rather than if the tap has a swivel spout or not :tounge_smile:
Someone hasn't turned the valve off on the hot side under the sink have they?. if its a lever ball valve it can happen accidentally.
No valve ok all hot taps working fine except this one and was working ok yesterday the cross head turns with no resistance as if broken in side You can see this tap in wicks catalogue called regan no 197632
if it came from wickes just replace it
It did not come from wickes that infomation was to show what the tap looked like How do I get the valve out
ok if its the same as the tap from wickes just change it
I cant change it as its now 3 years old i just want to repair it Do you know how to remove the valve
take of the head and unscrew the body
Reply to Kitchen monobloc swivel spout tap went to turn n hot tap and nothing no water at all in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Our kitchen mixer tap has started dripping. Like so much of the plumbing in our almost new build bungalow, it is lacking! The plumber didn't...
