Discuss Landlord dispute gas boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I have moved out of a house a week ago. Check out went fairly well but now a week later the landlord has claimed we have tampered with our gas boiler and said the valves have been blocked with silicone between feb 7th when british gas done a service and august. Claiming it will cost £312 to replace. Any advice as to why anybody would have done this would be greatly appreciated and does anybody have a estinate it would cost to truly repair
Yea the service engineer either the last one or the few before as they've snapped the head off the gas valve screw and was probably leaking so that's why the added silicon
Big nono, needs a new gas valve
Reminds me of a testpoint i rocked up to and i only looked at it and it sheared off. These two holes are the testpoints gas engineers use when servicing. It looks like a Potterton Suprima. It may be just possible to get them out and replace them, otherwise new gas valve as mentioned. The silicon is, well, not good and as it stands, if it is leaking, it should be isolated.
Thanks so much for your replies. My issue is the landlord is claiming i have done this. They are basically saying i have put my family and neighbours lives at risk. Would british gas not have picked up on this at the february service?
In the two years i have been at the property not once have i accessed the boiler and have never needed to
If damage was done to the system should i be seeking legal advice as to the risk my family could have been under when i wasnt informed? Surely british gas would have noticed this
Ask them why you would need to undo the pressure test points on a boiler answer you wouldn't push it back to British gas there problem, nothing to do with you
And tbh no they don't care (British gas)
Thanks mate. This has been really bothering me since i found out
If you didn't tamper with the boiler, argue your case. Basically, the L must refund the amount of money not in dispute, but due to new (2007) requirements on tenancy deposits, (s)he doesn't get the disputed money either until it has been through arbitration or court. And I'd like to see how They are going to prove you did this.
Tenancy deposit protection: Overview - GOV.UK
They are basically saying the british gas service was done in february and i have tampered with it since then.
They now have a report from their plumber which they are using as evidence so its up to me to prove i did not tamper
What's he saying and is he gas safe if he's not doesn't mean the paper it's written on
See if you can get the last service sheet done on the boiler or even the one before, if there are figures for boiler gas pressures then it helps to understand who touched it last, if fact any gas pressure test could really have been done from there. If the sheet states cannot be done as sheared off or any other comment, again it will help. It is a bit bizarre the landlord is pointing the finger at you but i suspect he wont know who has done what and i expect the service companies would be saying they would never do anything like that.....
Doesn't want to pay for a new gas valve so passing the book (Rubbish rolls down hill)
Yeah they'll say that (viz. that it's up to you to prove your innocence). But if you google the other side of the story you'll find plenty of landlords moaning about how unfair the arbitration services used by the TDS/DPS etc are and how they nearly always side with the tenant.
Your landlord has my sympathy because it seems like a bodge done by a gas installer and the gas installer is saying 'not me, honest gov'.
But you're innocent until proven guilty, and I see no motive for you fiddling with these screws so I doubt it was you and I suspect any arbitrator would see it in the same way.
Having been on the other side of the fence, I have experience of an idiot letting agency saying I could charge the tenants for xyz but then having no evidence of condition as the inventory was done so badly. I realised I didn't have a leg to stand on so I didn't even attempt to charge the tenants. Sound like your landlord is trying it... but how does s/he prove you did this unless there is photographic evidence of the parts of the boiler that cannot possibly be on the inventory because no one normally is able to access them? I agree: estate agents and Conservatives...
But just as the Conservatives got a kicking in the General, I think you'll win this if you just dispute your case and don't roll over and say okay, yes I'll pay it because you've scared me into thinking I can't win.
Thanks. You have made me more confident with my dispute claim
Interesting your landlord has claimed you must have tampered with the gas boiler and that you put your families lives in danger.
I would put those exact words straight back to your landlord as a quote, then further reply with your own words stating that only BG has worked on the gas boiler and since the landlord has said it has endangered you and your family, you now will be seeking compensation for the false allegations against you of damage to his property, of doing illegal gas work (to a gas appliance of which you are not Gas Safe qualified and have no reason or knowledge of to tamper with), and the danger he confirmed from the gas boiler that must be due to his service engineers faulty work.
Niall, if you have any emails etc of contact with your landlord or letting agent when anything has gone wrong or required repair in this property and you can show you have been a good tenant - e.g. letting BG in to conduct the gas safe checks etc then your landlord will find it impossible to hold you responsible. I would inform him that you understand that only a gas safe engineer can look at gas appliances such as the boiler / gas hob etc and therefore you would not touch it, especially as it would not cost you as a tenant to repair and this would be their responsibility and cost to pay. He is just trying to recoup the costs as there is no was he is going to get BG to cover the costs. If he cannot prove they are responsible it is even less likely he can do this to you. Was your deposit held in the legal deposit scheme?
It was yes. Thank you for your reply and advice mate
I have numerous texts informing them when the washing machine belt broke and shower packed up which they repaired. Why would they think i would mess around with a gas appliance is beyond me. I will seek legal advice when undisputed deposit amount clears
What gives your landlord reason to suspect that you have tampered with the boiler?
Having disputes with a landlord can make them find any excuse to blame you.
why would you tamper with any boiler when the landlord would get it repaired.call his bluff and contact gas safe no way are you responsible for this.
Thanks. I have submitted a form to hse that the landlord has never provided us with a gas safety certificate and the situation im in now
They have no proof that you did it, until they prove you did. Which is not going to happen, leave the ball in their court.
No its not its up to them to prove it, in a court they've got to prove its more likely that you did the damage rather than the last person to service it.
I always thought only gas safe engineers are allowed to open up a boiler anyone who doesn't hold the gas safe registered license will break the law. Hoewever, the pictures taken could be possible the ones from the landlord and he has opened up the boiler. Perhaps, somone of his guys, or himself has manipulated the boiler gas valve.
The way I would handle it, is exactly the way as @Best has described it. I wouldn't let anyone Soding me on my legs and it seems like they trying it with you now.
I think you just need to treat it as a legal matter and simply look at it as unproven allegations to attempt to extract money of you.
I would be fuming if a landlord accused me of that.
It is essential you have a letter sent immediately to reject the allegation. Keep a copy. You don't need a solicitor to do that first letter, but just keep it basic. Leaving it for a long period before replying seems wrong. Any court will want to see what your initial rely was, although highly unlikely it will go to court.
Do not ever mention later that you know anything about the gas boiler workings! You can later say you never have seen those parts, except in the photos and have been advised by Gas Safe and gas engineers that only a qualified gas engineer can legally remove a gas boiler casing and only normally for servicing.
Its being disputed through the deposit protection scheme. Im awaiting feedback from them. I have already reported the landlord to the HSE and hopefully it will be traceable as to who has done this or when. Im hoping this thread can be used as evidence with dps. Speaking to citizens advice in near future
Good! As long as any allegations made directly or indirectly against you are denied by letter(s) to each source.
It is always a paper trail.
Be it Landlord, Letting Agent, BG, or any other, - you send each a letter to deny any tampering with boiler. Registered post advisable and doesn't cost much extra for small envelope.
Destroy a person by words.
Keep us informed of each stage
Hahaha they don't do anything to effect the running costs
They don't change the amount of gas being used
Reply to Landlord dispute gas boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Article
A Plumber Who Worked Illegally Gets A Suspended Sentence After Falsely Claiming To Be Gas Safe Registered. A Plumber in Herefordshire was prosecuted after Hereford Trading Standards Team found that he was falsely claiming to be on the Gas Safe Register when he was not, putting members of the...
