Discuss lead pipes question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
plumbduff
What should be done if lead pipe work is found within a property?
if it isn't leaking leave it alone. incoming water I presume?
But try to get the customer to agree to have you replace the lead mains. Horrible stuff and can suddenly leak on the seam. Any lead pipe inside properties usually has to be from before the war - about 80 years old at least.
Think of the scrap value of the old pipe
I know hard water , was more likely to make a protective layer hence disturb nothing !
( flush toilet , run tap before drinking it in morning - was my routine in a mates house )
Reply to lead pipes question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I will need: install new 100mm pvc pipe work, 90-degree bend for new W/C install new 100mm pvc pipe work, 90-degree bend with new gully pot at...
Sonya K
Had the plumber replace the pipes less than 2 month from the sink that lead into a cast iron pipe. They also unblocked gunk from the start of the...
Hi there I’m 10 weeks pregnant and found out we have some steel galvanised pipes with corrosion which was causing our tap water to run...
