Discuss lead pipes question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
plumbduff
What should be done if lead pipe work is found within a property?
if it isn't leaking leave it alone. incoming water I presume?
But try to get the customer to agree to have you replace the lead mains. Horrible stuff and can suddenly leak on the seam. Any lead pipe inside properties usually has to be from before the war - about 80 years old at least.
Think of the scrap value of the old pipe
I know hard water , was more likely to make a protective layer hence disturb nothing !
( flush toilet , run tap before drinking it in morning - was my routine in a mates house )
Reply to lead pipes question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
