David66316
Hi everyone, just after a bit of advice as to whether I have done the right thing in this situation or not,
Customer phoned, wanted a pipe cutting back so it was under the floor boards instead of above where the airing cupboard used to be. I identified it as a heating pipe, so drained sytem down, cut pipe, soldered a few fittings and neatened it up under floorboards, but where I chopped on one of the sides had water in, not much but enoigh to soak my rag and go on the floor boards, so I used a compresiion fitting here. So left with satisfied customer untill today, customer phoned and said the ceiling has been stained from water upstairs where id been working. So I went back today, made sure my pipework was sound, and apologized and have now arranged a painter and decorator to repaint the ceiling.
So did I do the right thing by paying for this decorator to do this or should i have just left it and apologised, also whats the best way to avoid this happening again, should i use a wet vac? or just more rags, as it was under floorboards i couldnt use a bucket or tray it was too tight,
thanks in advance
thanks in advance
