Discuss Leaking inline at joint with copper pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Depends where it's leaking from most likely will need replacing!
Reply to Leaking inline at joint with copper pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have attached an image of the brass body within a tap. Having replaced a cartridge which has cured a leaking tap, I can see that there is a...
PSxxxxxx
