Discuss Leaking pressure valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
K
kkelly77
I was fitting TRV's to the CH system in my house the other day. I also replaced the drain valve as the original was seized closed. The pressure relief valve on the boiler was also broken, gauge was reading zero.
When I fitted everything and refilled the system, I saw the pressure valve was leaking from the connection even though I had plenty of PTFE on it. I took it off and removed all the PTFE and took a wire brush to the male connector on the boiler. Wrapped it in PTFE again and refitted. It's still leaking :mad:
Am I doing something wrong?
K
Hemp and boss white would sort that out!
And the discharge pipe needs to be fitted too
Use lock tight and jet blue, ...your gauge is reading over 4 bar in the secound pic??this is far to high!!
Should I wrap it in hemp and boss white instead of the PTFE? What does a discharge pipe look like as the old valve did not have one on it
The second pic is of the old pressure valve. Gauge was reading zero during the current freeze we had. One of the days it went up to 4 bar for about 30 secs and then returned to zero. Currently reading ~1 bar
or you could be wrapping ptfe the wrong way,as said ptfe and jet blue
Reply to Leaking pressure valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have been facing central heating low pressure on unvented hot water RM Cylinders but can't see any leak on the PRV, expansion vessels and...
losing pressure
L
Hi Just had a new bathroom installed with a toilet bowl that reaches the back wall. Its has a bottom entry cold feed to the cistern. The fitter...
1K
Hi, all. I have a leak problem behind the washing machine. It's a pipe that is leaking directly into a drain. It used to drip but now is leaking a...
Pritesh Patel
Can central heating / gas engineer expert help me with below issue. During winter time only, I have been having issue with low pressure or...
J
I have an Arteform shower valve in my bathroom - top lever for the main shower head, middle for the handheld hose and bottom is the thermostatic...
