Discuss Leaking push fit joint in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I put a new bath in my daughter's en suite about a month ago and everything was fine until last night. She rang to say water was dripping down the wall in the porch immediately below the en suite. When I installed it the hot supply came up through the floor in 22mm Hepworth plastic pipe, I put a 22 to 15mm Hep2O reducer on this with the correct inserts and all was ok. The drip was coming from where the 22mm pipe went into the 22mm fitting. I took the fitting apart but could not see anything wrong so just cut the pipe slightly shorter( in case there was a nick in the pipe I couldn't see) put a new Hep2O insert in and instead fitted a 22 to 15mm Speedfit reducer. This is the first time I have had a leak from a Pushfit fitting, has anybody any ideas why it should leak particularly after being perfectly OK for a month or so?
I should add that they have had a leaking thermostatic mixer valve on their mains pressure hot water cylinder and the heating engineer has had them turning an isolating valve off when they are not using the hot water as it was leaking quite badly. He is fitting a new valve today. I don't really see why this should have caused the leak to the bath but it seems a bit of a coincidence.
Did you tighten up the fittings on the speed fit fitting?
I have had some issues lately with speed fit fittings . Only Monday fitted a 15 mm tee which I bought in a sealed bag.
Fitted it went downstairs turned on main , got upstairs water spraying out if it.
Same again couldn't see anything wrong when I checked it over.
I have come across it on new builds as well with poly plumb . Been on couple years and blam starts leaking for no reason.
Same as everything now build quality of a chocolate fire guard.
Reply to Leaking push fit joint in the Plumbing Jobs | The Job-board area at PlumbersForums.net
In the photo there is a grey 32mm push fit elbow between the sink trap and down pipe. I want to replace the elbow with a "male" push fit tee...
Hello, I have a troublesome fixed 15mm copper pipe with isolation valve going to my toilet fill valve. It's too tight for a Flexi hose. Can I use...
I have discovered a very old end feed 22mm t connector under the bath is very gently weeping water. It’s in a place and with pipework that are...
A
Hi, I am replacing a leaking push fit flexi tap connector under the bath with a compression fitting flexi. The problem is that the old pipe seems...
Hi, I am probably being unduly paranoid here but I noticed under our kitchen sink that there is some corrosion evident on a small section of...
