Discuss Leaking Water Tank Help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Doomsnite
Hello
We have a condenser boiler downstairs with the water tank upstairs. We have water dripping constantly out of one of the pipes at a rate of a bucket full every 2 days. Before we call a plumber, I just wanted to see if there is something I could be tightening to make it stop but dont know what I am looking at!
The bigger picture shows the leaking pipe in relation to the rest of the pipework.
The smaller picture shows where the water is coming out in the red circle. The yellow circle shows where there is a square nut thing which could be tightened. its one of those you can use with a spanner or a special key. The blue circle shows the only other point on the pipe where I think it could be tightened with a spanner.
Which of these, if any, should I have a go out? Any help and advice appreciated! :smile5:
Thanks. Is there a way to shut the water off behind it somehow?
Also why would it suddenly loosen, we never touch it ?
This one of the best posts I have seen for ages - photos and well presented
simple straighforwards advice in return. Fittings just leak sometimes thats why
we are all in business I suppose. centralheatking
Why is that, what exactly is it for? It has never leaked in the 5yrs ive been here until now. Thanks all
Do you see the valve bottom left with the red tag attached? Turn that off, open any hot tap till it stops running then close the hot tap. You should be able to nip it up and then control re-pressurising the system via the 'red tag' valve! If you're feeling brave you can even try removing the drain-off spindle and renewing the rubber washer on the inside ... Alas these are usually soldered without removing the rubber sealing washer which doesn't do them any good at all!
I'm assuming its an unvented cylinder judging by the stopcock, pressure reducing valve and tundish! :)
I missed the above before I tried it. Just tightened it a half turn and seems to have done the trick, the constant drips have stopped. Have left the bucket under there for the day and will check later if anything else creeps out. Thanks all!
Reply to Leaking Water Tank Help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
PSxxxxxx
