Discuss Leaky Connector in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
chuggers
Hi
I have notice I have leaky connector in my main water tank, I have replaced the connector which sloe down the leak, upon further inspection the slow leak is from hair line crack in the bottom of the tank which is under the connector, (This could of be done when I removed the old one) over time connector started to leak again but from the top of the connector,
Is it possible that the hair line crack is causing the to flow of water to come out from the top of the connector or is this because the connector is not on straight or not fitted correctly
Any help will be great
Hi
Photos speak louder than words, good photos do with the flash on
Could the 'hair line crack' have been made slightly bigger through vibrations so it now seems as if it is coming out of the top of the connector?
But yes i agree, photos always speak louder than words
Unable to good photos to the access to the connector very hard to get a clear shot
Right can you explain where it's leaking from and does it look like this one
Reply to Leaky Connector in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
