Discuss Legality of removing a boiler and re position in same room ? in the Gas Engineers Forum area at PlumbersForums.net
Jobbing builder …. Has taken boiler down and flue etc . Refitted on another wall in the room . Complete with flue
No gas safe cert issued . Local council are saying it would not need to be notified
Is this Jobbing builder Gassafe registered and with the correct categories to install boilers, presumably in a Domestic property and is the boiler connected, including gas supply and working?
And was it connected, including Gas supply and working prior to his / her removal of it?
Jobbing builder . Not a chance of been Gas safe . He did not even have liability insurance etc !
Boiler was fine . But i was wondering if its still needs notifying when been moved etc ??
I am lost for words that you think getting the boiler registered is far more important than getting it installed safely .
Sleep well .
The Gas Safe website has a "Concerns & Reporting Illegal Gas Work" page with links to appropriate report forms.
You need to get a registered gas engineer to re-install the boiler and issue the appropriate paperwork. Get the builder to pay.
(Have you checked that the builder didn't subcontract the gas work? It'd have to be a really stupid builder who risked moving a boiler themself and a really stupid property owner who allowed them to do it!)
If the Local Authority for that area say it doesn't need notifying to them, then it doesn't.
Notification is a minor issue in the situation, whether the boiler has been installed safely and by someone suitably experienced and Gas safe registered is the main issue.
Was this boiler part of larger works and has the builder invoiced and been paid and is fitting the boiler mentioned on the invoice?
Did the builder quote for moving the boiler and is moving the boiler mentioned on the invoice?
Sleep well .
Read it again ..... I was asked if the boiler was working fine before it was removed and refitted etc
Job was mainly "cash in hand ". Lots of issues , New consumer board and wiring carried out .Now lots of issues upstairs .As they pulled the ceilings down and hacked at cables etc . All I would like confirming is the legality .Even for a GSE to remove a boiler and refit it . Would it need to be notified under the GS scheme for it to be a legal install ?
Doesn’t need to be notified again now if it was moved into a new extension yes it would
so only issue would be the fact he was not a GSE ? I find it amazing that on some sites they claim it would need to be registered etc etc .Is this yet another case of the whole scheme is not policed correctly. British gas came today as there was a smell of gas and the engineer was not interested in it not been fitted by a GSE !
Correct and hse issue also void if manufacturers warranty
No warranty etc . But there is not ONE single route to take to have people like this fined etc ! The council are not worried etc .If this was Germany or the USA .The wold comes crashing down on people who do illegal work etc
Only if the homeowner reports it
electrically, if you are in England or Wales you need to comply with Part P and the electrician should provide you with certificates too
if you don’t have these, then you’re on your own when thing go wrong and / or you want to sell. Your insurance might be invalid too
cash in hand means you are enabling tax evasion
In order for it to be illegal work, it has to be established that the person who did the work, should not have.
That would apply anywhere in the World.
So consider this,
The builder is questioned about who did the work related to the boiler.
He says he got someone in who said they were Gassafe registered.
The Gassafe guy disconnected the gas, the builder removed the boiler (hence his DNA and fingerprints are all over it)
The builder helped the Gassafe guy fix the boiler on the wall and the Gassafe guy connected the water and gas and commissioned the boiler and was wearing gloves.
The builder paid the Gassafe guy cash, with the promise that he would send on paperwork for the boiler install.
He didn't and the builder has tried but has been unable to contact him.
What's the builder guilty of?
What's the non existant Gassafe guy or gal guilty of.
Or the builder could just as easilly deny ever having touched the boiler, (DNA and fingerprints might disprove that unless he was wearing gloves.
You'll need evidence the builder was asked to move the boiler.
Evidence he personally did move it and leave it switched on and working, whether safely or not.
Evidence that he was paid for it having invoiced for the work might go against him, but doesn't prove he actually did the work.
If the boiler is found to be unsafe or has injured someone then the incident is more likely to be thoroughly investigated, but the outcome could still be the same as above.
Reply to Legality of removing a boiler and re position in same room ? in the Gas Engineers Forum area at PlumbersForums.net
  • Article
A Plumber Who Worked Illegally Gets A Suspended Sentence After Falsely Claiming To Be Gas Safe Registered. A Plumber in Herefordshire was...
