Discuss Likely a stupid question in the Gas Engineers Forum area at PlumbersForums.net
Riley
Super Moderator
S. Mod
Subscribed
Apologies if this is a dumb question but is it against gas regs to swage a copper gas pipe?
That’s what I was thinking. I happened to come across last years gas safety cert at a property I was working in and the engineer had marked it down
Hmmm so this is a correctly formed socket not the best solder job I grant you but gas tight and as far as we know, to regs
Nope your fine
Nope same also the twitter lot only do them these days
Actually now you’ve said that I think I saw the other day someone saying illegal swaged gas pipe to PB. Were they just winding up?
Following up with this I bought some swaging drill bits. 15mm bloody brilliant 22mm not so much. Doesn’t seem to make a deep enough socket for the pipe to push into, the bit is marked 7/8” so is 22.2mm is this a big enough socket?? I can’t really see what else I could be doing wrong other than a poorly manufactured bit? Anyone know of a decent 22mm swage bit?
Get the grinder on it to remove the lip will let you go deeper
yes should be as copper varies dia and wall thickness
Cheers mate it just felt like I wasn’t able to insert the male pipe far enough. Perhaps only 4-5mm going in
I see so it’s not fully going in try heating up the copper first or you do need some pressure forcing down into the pipe
Goes all the way in to the stopper but doesn’t seem to make a full socket. Was wondering if 7/8 was big enough
I opened a thread on this a while back, they were quite expensive at the time I think around £30 a piece.
Do you recall the brand mate. Sorry to tread on toes
Not at all. Actually cost more - 22mm is over £40, links are at the end of this thread.
I’m still hoping someone will design something that you can cut the pipe out of a fitting like the yanks do eg socket saver
I'm curious as to why the imperial 7/8 was so Rubbish, I might get a crap set and have a play. I like using my monument former when I get a chance but obviously you've got to form it while it's being hand held rather than already half clipped to the wall.
Well let me know how you get on I got mine on flea bay just to try them so I’m not too bothered as they were a cheap way to test the process
There was a link to something similar in an enquiry thread showing a long vertical waste pipe that had cracked feeding into what looked to be some sort of inspection base. Ahh just seen it and like you said earlier Shaun, a socket saver.
Reply to Likely a stupid question in the Gas Engineers Forum area at PlumbersForums.net
