Discuss Listening stick in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sanke
Hi guys
I need to find a leak which is under a concrete screed Does anyone know where I can get a listening stick or is something else better
Thermal image camera is a better way to pin point a leak. You can hire them if you don't want to spend a couple of thousand quid buying one.
Leak is on plastic pipes for rads under screed / insulation about 6 inches down
As already said, turn heating on and use a thermal camera. You are not going to get leak vibrations to use what you have mentioned.
Water will be cold Pressure plummets before we can get it warm How much for thermal camera ???
Reply to Listening stick in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the...
Hi guys. I'm trying to identify a toilet model before ordering a seat for a customer. I went to what used to be a Roca stockist (they no longer...
