Discuss loose toilet seat, screws wont tighten in the USA area at PlumbersForums.net
Hello
I cannot get my toilet seat to tighten.
I have no access to underneath the toilet. I have taken the toilet seat off and tightened the screw, but it just keep spinning. As if the hole diameter is too big.
I've tried the rubber expanding fittings and the plastic ones of similar style.
Is my only option to remove the toilet from the wall and put some lug nuts on?
You should be able to find some stainless steel toggles that are made for that purpose.
They come with plastic handles and the plastic snaps off when you pull the toggle up tight.
I just cannot think of what they are called at the moment.
Hello
Post a piccy for more answers Chking
If it is new then fine, try and find fixings but if it's done it's duty why not replace? A new bog seat is always nice and always looks better. Plenty of top fix seats available.
Reply to loose toilet seat, screws wont tighten in the USA area at PlumbersForums.net
A
I have a RAK toilet and seat, the seat keeps coming loose on one side, I tighten the screw but it doesn't last long. My question is will a...
Just moved into a new place and the toilet seat is super loose. Spent about 2 hours trying to figure out how to tighten this toilet seat. I did...
I tried to install a new toilet seat and I’m stuck in a process where I couldn’t loosen or tighten the screw. I also tried rotating the screw in...
Jacuzzi toilet seat fixings are loose and I cannot figure out how to tighten them. Nothing seems removal and they cannot be accessed from...
2K
Hi! Hoping for a bit of help! Thought I had an easy job of changing my toilet seat however it seems to be more challenging than I thought. It...
1K
