Discuss Low pressure once got water arrives at outlet in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Problem is with a directly heated invented cylinder.
All outlets shower included.Is this only 1 tap or all of your hot taps.
What sort of tap Is it? Has the problem always been there or is it something new? How does your cold water flow rate compare to the hot water?
Fairly common problem with a couple of possible causes. Not fixable by the end user. You need a G3 (unvented) qualified engineer to attend and service the system.
Daughter's a place Has not been in long doubt been looked at in years.
Has the system been serviced annually by a qualified person? These systems do need periodic maintenance/checking by a competent person.
Doubt it has been looked at in years.Fairly common problem with a couple of possible causes. Not fixable by the end user. You need a G3 (unvented) qualified engineer to attend and service
Will get daughter to sort it out as is her gaff!By what you've said the fault definitely lies with the cylinder/component. As mentioned above, get a g3 qualified engineer in to look at your system.
Reply to Low pressure once got water arrives at outlet in the Plumbing Jobs | The Job-board area at PlumbersForums.net
