Discuss Magnetic filter position in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Matt0029
I no a magnetic filter should be fitted on the return after the last return contaction to the boiler. However on a open vented system I could fit one in the cylinder cupboard. That would be after all the return connections for the central heating but the hot water primary return would be teed in after the filter close to the boiler. Would this take away the advantage of a filter totally?
As Scott says the corrosion is going to generate in the CH circuit, unlikely the HW coil so that sounds ok yes. Any doubts just check with the boiler manufacturer. They’ll have the last word ultimately.
This is what Adey recommend 👍
Reply to Magnetic filter position in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Just had a new Worcester Bosch Greenstar 30Ri fitted with the magnetic filter. When the system is running the boiler is so quiet but there is a...
I just had a quote for a new boiler install as follows I dont undertand why a 15-60 boiler pump is needed and a 25-100 pump is needed as well I...
Hi All This is following on from thread I made a few days ago but can't seem to find I'm in a bit of a bind with my CH design where I want to...
J
I have an old (~2006) Potterton powermax boiler. It's a gas system boiler with a small unvented cylinder in one small package, in a flat. Because...
1K
Hi all. As the title says, I have a problem with an unvented cylinder I had installed last year where the first time I turn a hot tap on after the...
2K
