Discuss Main combi 24 HE, heating starts and stops in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi All, Hope someone can help with this one too. Main combi 24 HE, heating fires up as normal then stops after about 30 seconds. Any thoughts? Hot water works fine.
Definitely say the Diverter or the motor then. If rads are getting hot, then either the motor isn’t moving or the Diverter pin is stuck, since you’ve replaced the Diverter on a whim, I’d say the motor. You could confirm this by testing with a mm.
Reply to Main combi 24 HE, heating starts and stops in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
