Discuss Master Soldering help needed for a clean solder in the Plumbing Forum area at UKPlumbersForums.co.uk.
  1. Electronurd
    Electronurd Member
    i would love joins like this guy and would love to see his video but it won't load...:32:
  2. Electronurd
    Electronurd Member
    Finally see the guys video. He seems to use tons of flux and just barely touches with the solder wire. I think that's where I'm kinda going wrong as I'm leaving the solder wire on till I see it coming out.
  3. rpm
    rpm Trusted Plumber
    Anyone used copper push-fit?
    Just asking!
  4. 1Steven
    1Steven Plumber GSR
    Practice and have patience.
  5. zzzjim
    zzzjim Well-Known Member
    Not "THAT product again" ,
    if you need an electrical connection ( Earthing for safety )
    maybe a glue is not relevant !
  6. JCplumb
    JCplumb Plumber
    The lamp you are trying to emulate isn't soldered, that's how you don't see any snots (runs of solder), at a guess I'd say it's glued.
  7. JCplumb
    JCplumb Plumber
  8. Electronurd
    Electronurd Member
    Well that's what I thought and so I sent the seller a message to ask before any potential purchase and they did confirm that all joins were soldered.
  9. Last Plumber
    Last Plumber Plumber GSR Top Contributor!!
    Once it's at the right temperature you only need to touch it and you'll see it flow.
    The reason I said use flux sparingly was because you do not want to allow solder to run on the pipe outside the fitting. If I were doing your task I would flux inside the fitting with a flux brush and put just enough on the pipe to cover the length of the full socket.
    If poss, try to solder with gravity on your side !
    • Like Like x 1
  10. Electronurd
    Electronurd Member
    Excellent tips. I'm going to try again today but practice on some crappy bits first. I'll post any pics I have if they turn out ok.
    • Like Like x 1
  11. Last Plumber
    Yes do that, I'd like to see the finished product !
    I realise you want to solder this to perfection but just in case you do have a bit on show, Emery ribbon ( fine grit), will remove solder easily and polish the copper nicely too.
    That might make it even easier for you !
  12. Last Plumber
    I mean the stuff you use in engineering, do you know which I mean ?
    It comes on a roll
  13. Electronurd
    Electronurd Member
  14. Last Plumber
    That will probably do but the stuff I meant is finer ( not like sand paper ).
  15. Electronurd
    Electronurd Member
    Ah do you think you be could post a link to it? I'm going to screwfix today so would be great to pick it up whilst I'm there.
